14 years agoUpdate nios-linux 20100621 buid error
After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/...
13 years ago --- Quote Start --- --- Quote Start --- After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/memory.o] Error 1 make[2]: *** [arch/nios2/mm] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/root/nios2-linux/linux-2.6' make: *** [linux] Error 1 --------------------------------------------------------------------------------------------- Hallo kinhcan89, can u tell me how did you solve this Problem? i am having the same one! i Know its one year ago but maybe u remember :-). --- Quote End --- Which toolchain do you use and which branch do you use (mmu / nommu)?
