14 years agoUpdate nios-linux 20100621 buid error
After update nios-linux 20100621, when i make, get error : {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/...
14 years agoGot same error when starting to play around with uclinux some time ago.
Hope I remember right when I tell you to check a) your branches b) your toolchain So when working without mmu you should use nios2gcc-20080203.tar.bz2 and test-nios2 branches, when working with mmu you should use toolchain-mmu and branches trunk (uClinux-dist) / nios2 (linux-2.6) Hope this helps. Andi
