16 years agoUpdate FPGA config data and NIOS software via RS232
Hi, I am fresh in FPGA design. Right now, I am updating the sof n elf file to the FPGA board by the USB Blaster and the Flash Programmer. I would like to updated these files by the RS232, and ...
16 years agoThis particular feature has been addressed many times on the forum. Refer to the following:
http://www.alteraforum.com/forum/showthread.php?t=4799&referrerid=2226 http://www.alteraforum.com/forum/showthread.php?t=4192&referrerid=2226 http://www.alteraforum.com/forum/showthread.php?t=20623&referrerid=2226 In fact just to a google search on "NIOS" and "Remote Update" Basically you have to worry about 3 things: 1 - Downloading the fpga and NIOS software images to the board via RS232. Obviously you're going to have to write your own software for this (both on PC and NIOS) 2 - Program the fpga and software images into flash. You're using a NIOS so using the CFI flash controller or EPCS controller is your easiest bet. 3 - Triggering a reconfiguration once you have downloaded the image. Now you haven't stated what your configuration scheme is or what type of flash you are using. Jake
