21 years agoUnusual output pin behavior
Hello: I've got a cyclone device with a NIOS II processor. It is using a interface to user locig that is tied to an SRAM device. The SRAM is 3.3 volts. I'm seeing strange beh...
21 years agoGeorge,
Are you sure you tied your VCC/IO pin for Bank 0 to 3.3 Volts? (Possibly pin 29) I would check your VCC/IO pins on your board to be sure that they are all tied to 3.3 Volts. Good Luck!! Brandon
