16 years agoUnrecognised Instruction Flushda Error
Hi,everybody.I encountered a error as the following when i compilered the uclinux kernel. I followed the steps like:
http://www.nioswiki.com/installnios2linux My OS is ubuntu9.04 gcc is 4.2 Platform is DE2_70 Could anybody help to fix it, Thanks.:) ---------------------------------------------------------- LD usr/built-in.o CC arch/nios2/mm/memory.o {standard input}: Assembler messages: {standard input}:96: Error: unrecognised instruction flushda {standard input}:232: Error: unrecognised instruction flushda {standard input}:364: Error: unrecognised instruction flushda {standard input}:427: Error: unrecognised instruction flushda make[3]: *** [arch/nios2/mm/memory.o] Error 1 make[2]: *** [arch/nios2/mm] Error 2 make[1]: *** [sub-make] Error 22 Replies
i fix this problem:)
Uh, how did you fix this error? I'm getting it too.
