21 years agoUnnecessary instructions
Hello, it's my first post. I have question about GCC generated code. We can find several unnecessary instructions. --- sample code --- unsigned short uh; uh = IORD_16DIRECT(base,ofst)...
21 years agoThank you Jonah.
I make a sense in technically. But I do not understand that this issue has not higher priority. I think RISC processor's performance is not only hardware's, but also compiler's performance is needed. These codes will reduce much performance at /e core or all Nios II without DSP block. (x30@16bit, x50@8bit data). I hope compiler enhancement will get more higher priority. Regards, marm
