15 years agoUnknown compiler error.
Hi, there.
When I C2H'ed the function and compiled it, I got the message below, Error: CPU0/instruction_master: Base Address for accelerator_nkc_eva_checksum_managed_instance/cpu_interface0 must be a multiple of its span 0x40. Error: CPU0/data_master: Base Address for accelerator_nkc_eva_checksum_managed_instance/cpu_interface0 must be a multiple of its span 0x40. Error: System generation failed. make: *** [c2h_hdl-t] Error 254 Does anybody knows why? I arranged the address of the function to a multiple of 0x40 in SOPC Builder, but there was no change. Thanks in advance. -- KanoPapa1 Reply
Inspect the .tcl file generated for the hardware accelerator that is responsible for making all the master/slave connections. It could be that it is not generated correctly. Also try moving the slave port to a larger multiple than 0x40 to see if that corrects the issue (i.e. 0x80, 0x100, etc...)
