20 years agoundefined reference to '__ctype_b'
hi,
Has any body ever encountered the problem of "undefined reference to __ctype_b" when linking with NIOS IDE before? I got the following error while linking using nios-elf g++ Note: the reason why it's reporting __ctype_b_loc instead of __ctype_b is because I went into Microtronix uCLinux include directory, and changed all ctype_b to ctype_b_loc in ctype.h as suggested by this: http://www.molpro.net/molpro-user/archive/all/msg01417.html (http://www.molpro.net/molpro-user/archive/all/msg01417.html) I also tried using a bigger libc.a as well (which was not in microtronix uCLibc directory), but it didnt help. Any help would be greatly appreciated! Thanks! ERROR MESSAGE: Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer (at 0x000a95e0) because the offset (-693728) is out of the allowed range, -32678 to 32767.[Debug/libAutoClip.a(clp_obj.o)(.text+0xa4):../../../../C_RT/Source/clp_obj.c] undefined reference to `__ctype_b_loc'[../../../../C_RT/Source/clp_obj.c] *169: undefined reference to `__ctype_b_loc' ../../../../C_RT/Source/clp_obj.c:169: Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer (at 0x000a95e0) because the offset (-693728) is out of the allowed range, -32678 to 32767. libAutoClip.a FROM CONSOLE: nios2-elf-g++ -nostdinc -D__linux__ -O0 -g -I"c:/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2_51/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -I Connective_Logic_Systems/CLIP/BSP/Posix/Include -I Connective_Logic_Systems/CLIP/C_RT/Include -I Connective_Logic_Systems/CLIP/CPP_RT/Include -I Connective_Logic_Systems/CLIP/Operating_System/Posix/Include -I Connective_Logic_Systems/CLIP/Protocol/TCP_for_Posix/Include -I FFTW/fftw/Include -I PROSAS_Source/DataClasses/Include -I PROSAS_Source/Harnesses/Include -I PROSAS_Source/Infrastructure/Circuits/Include -I PROSAS_Source/Infrastructure/CxnPrototypes/Include -I PROSAS_Source/InputOutput/Devices/Include -I PROSAS_Source/Interfaces/Include/ -I PROSAS_Source/Processing/Include/ -I PROSAS_Source/ProjectHeaders/Include -I PROSAS_Source/Topics/ClpConfigDev -I PROSAS_Source/Topics/ClpList -D_DEBUG -c PROSAS_Source/InputOutput/Devices/Source/WatchDogDev.cpp -o Debug/WatchDogDev.o nios2-elf-g++ Debug/ProcAFEstData.o Debug/ProcAzFftData.o Debug/ProcAzIFftData.o Debug/ProcAzMocompData.o Debug/ProcData.o Debug/ProcInputData.o Debug/ProcOutputData.o Debug/ProcRgMocompData.o Debug/ProcRmaData.o Debug/ProcRpAdjData.o Debug/ProcTRData.o Debug/ProSASData.o Debug/ProcAFEstAdjCellMthd.o Debug/ProcAFEstAFLineMthd.o Debug/ProcAFEstCellProcessMthd.o Debug/ProcAFEstFFTMthd.o Debug/ProcAFEstIFFTMthd.o Debug/ProcAFEstPointMthd.o Debug/ProcAFEstRMAMthd.o Debug/ProcAFEstSetupMthd.o Debug/ProcAzFftAzFftMthd.o Debug/ProcAzFftCopyBackMthd.o Debug/ProcAzFftSetupMthd.o Debug/ProcAzIFftAzIFftMthd.o Debug/ProcAzIFftCopyBackMthd.o Debug/ProcAzIFftSetupMthd.o Debug/ProcAzMocompAzMocompMthd.o Debug/ProcAzMocompCopyBackMthd.o Debug/ProcAzMocompSetupMthd.o Debug/ProcInputFepRxThrd.o Debug/ProcInputReadThrd.o Debug/ProcOutputWriteThrd.o Debug/ProcRgMocompCopyBackMthd.o Debug/ProcRgMocompRgMocompMthd.o Debug/ProcRgMocompSetupMthd.o Debug/ProcRmaCopyBackMthd.o Debug/ProcRmaRmaMthd.o Debug/ProcRmaSetupMthd.o Debug/ProcRpAdjcopyBackMthd.o Debug/ProcRpAdjRpAdjMthd.o Debug/ProcRpAdjSetupMthd.o Debug/ProcTRTRMthd.o Debug/ProcAFEstCct.o Debug/ProcAzFftCct.o Debug/ProcAzIFftCct.o Debug/ProcAzMocompCct.o Debug/ProcCct.o Debug/ProcInputCct.o Debug/ProcOutputCct.o Debug/ProcRgMocompCct.o Debug/ProcRmaCct.o Debug/ProcRpAdjCct.o Debug/ProcTRCct.o Debug/ProcAFEstCpt.o Debug/ProcAzFftCpt.o Debug/ProcAzIFftCpt.o Debug/ProcAzMocompCpt.o Debug/ProcCpt.o Debug/ProcInputcpt.o Debug/ProcOutputCpt.o Debug/ProcRgMocompCpt.o Debug/ProcRmaCpt.o Debug/ProcRpAdjCpt.o Debug/ProcTRCpt.o Debug/BittwareAPI.o Debug/dspDev.o Debug/GenDspDev.o Debug/LedDev.o Debug/ProSAS.o Debug/WatchDogDev.o -o Debug/MISER_SCH.exe Debug/libAutoClip.a Debug/libClip_pp.a Debug/libClip_PP_Process.a Debug/libAutoClip.a(clp_obj.o)(.text+0xa4): In function `obj_init': ../../../../C_RT/Source/clp_obj.c:169: undefined reference to `__ctype_b_loc' Debug/libAutoClip.a(clp_obj.o)(.text+0xa4):../../../../C_RT/Source/clp_obj.c:169: Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer (at 0x000a95e0) because the offset (-693728) is out of the allowed range, -32678 to 32767.5 Replies
Maybe the problem is not linked to the LibC, but to the application having too much small data, because the first error message is "Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer"...
Try with a dummy application without too much data... does it works? If yes, that's probably the reason... Paolo - Altera_Forum
Hi Paolo,
It does work when I link to a dummy application. However, is there a way to increase the size though for global pointer though? Because we tried compiling and linking the same project under Fedora Core 4 with the gcc version 3.4.1, and it linked in just fine. Thus, we suspect this is a NIOS-II-specific problem? What does everybody think? Thanks! Shivesh --- Quote Start --- originally posted by paolo.gai@Jan 13 2006, 04:06 AM maybe the problem is not linked to the libc, but to the application having too much small data, because the first error message is "unable to reach __ctype_b_loc (at 0x00000000) from the global pointer"...try with a dummy application without too much data... does it works? if yes, that's probably the reason...
paolo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12171)
--- quote end ---
--- Quote End ---
--- Quote Start --- originally posted by shachris23@Jan 14 2006, 03:37 AM it does work when i link to a dummy application. however, is there a way to increase the size though for global pointer though? because we tried compiling and linking the same project under fedora core 4 with the gcc version 3.4.1, and it linked in just fine.thus, we suspect this is a nios-ii-specific problem?
what does everybody think?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12190)
--- quote end ---
--- Quote End --- Yes, because the Nios compiler uses a register to speedup data access. In general you cannot increase the amount of GP-relative memory, but there are two ways: You can either - compile using the -G0 option or, - put your small data (global ints, global chars, ...) inside a struct, or allocate them in another section... you can try something like
the section attribute must stay both in the declaration and on the definition of the variables. There is also a section about that in the ERIKA Enterprise manual, section 4.8.4, available for free at the evidence literature page (http://www.evidence.eu.com/nios2/literature.asp) bye Paoloint foo __attribute__ ((section (".data"))) = 57; int bar __attribute__ ((section (".bss"))); // initialized to 0 - Altera_Forum
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Hi Paolo and everybody,
The problem is solved. The error happened because of the link flags that I passed when the program was linking. At first, I didn't strictly follow Microtronix's linking flags, and just used $(CC) -o <program> $(MYLIBS) $(LDLIBS) And when I changed to $(CC) $(LDFLAGS) -o <program> -lpthread $(MYLIBS) $(LDLIBS) Voila, the program links with no problem. So I guess the lesson learned is if it aint broke, dont mess with it. But thanks Paolo so much for your detailed response. I sure learned new things, and I will try it next time I encountered problems like this again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif --- Quote Start --- originally posted by paolo.gai+jan 14 2006, 03:21 am--><div class='quotetop'>quote (paolo.gai @ jan 14 2006, 03:21 am)</div>--- quote start ---
<!--quotebegin-shachris23@Jan 14 2006, 03:37 AM it does work when i link to a dummy application. however, is there a way to increase the size though for global pointer though? because we tried compiling and linking the same project under fedora core 4 with the gcc version 3.4.1, and it linked in just fine.
--- quote end ---
the section attribute must stay both in the declaration and on the definition of the variables. There is also a section about that in the ERIKA Enterprise manual, section 4.8.4, available for free at the evidence literature page (http://www.evidence.eu.com/nios2/literature.asp) bye Paolo <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12193)</div> [/b] --- Quote End ---int foo __attribute__ ((section (".data"))) = 57; int bar __attribute__ ((section (".bss"))); // initialized to 0 - Altera_Forum
Sorry. To be more accurate: g++ under Windows or Linux? I knowed that g++ didn't work under Linux. Right?
--- Quote Start --- originally posted by shachris23@Jan 17 2006, 01:16 AM http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif hi paolo and everybody,the problem is solved. the error happened because of the link flags that i passed when the program was linking.
at first, i didn't strictly follow microtronix's linking flags, and just used
$(cc) -o <program> $(mylibs) $(ldlibs)
and when i changed to
$(cc) $(ldflags) -o <program> -lpthread $(mylibs) $(ldlibs)
voila, the program links with no problem.
so i guess the lesson learned is if it aint broke, dont mess with it.
but thanks paolo so much for your detailed response. i sure learned new things, and i will try it next time i encountered problems like this again. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
--- quote start ---
--- quote end ---
--- quote start ---
<!--quotebegin-shachris23@jan 14 2006, 03:37 am
It does work when I link to a dummy application. However, is there a way to increase the size though for global pointer though? Because we tried compiling and linking the same project under Fedora Core 4 with the gcc version 3.4.1, and it linked in just fine. Thus, we suspect this is a NIOS-II-specific problem? What does everybody think? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12190) --- Quote End --- [/b] --- Quote End --- Yes, because the Nios compiler uses a register to speedup data access. In general you cannot increase the amount of GP-relative memory, but there are two ways: You can either - compile using the -G0 option or, - put your small data (global ints, global chars, ...) inside a struct, or allocate them in another section... you can try something like
the section attribute must stay both in the declaration and on the definition of the variables. There is also a section about that in the ERIKA Enterprise manual, section 4.8.4, available for free at the evidence literature page (http://www.evidence.eu.com/nios2/literature.asp) bye Paolo <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12193)</div> [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12228)</div> [/b] --- Quote End ---int foo __attribute__ ((section (".data"))) = 57; int bar __attribute__ ((section (".bss"))); // initialized to 0
