20 years ago
uncompressing of romfs.img
hello friend
i have one prblem->
i have dump my u-boot ,kernel and filesystem with following data
flash: 0x00000000----0x0020000(2MB)
sdram: 0x00800000----0x00ffffff(8MB)
restart address: 0x00000000
exception address: 0x00800020
u-boot download address: 0x00000000
the kernel of uclinux download address: 0x00020000
the kernel of uclinux load address is 0x00800000
the kernel of uclinux entry address is 0x00800000
the filesystem of uclinux download address: 0x00100000
the filesystem of uclinux load address is 0x00a00000
the filesystem of uclinux entry address is 0x00a00000
u-boot is 100k
vmlinux.bin.gz is 450KB
romfs.bin.gz is 438KB
and
i use the command to compress the kernel : gzip -9 vmlinux.bin
mkimage -A nios2 -O linux -T kernel -C gzip -a 0x00800000 -e 0x00800000 -n 'Linux Kernel Image' -d vmlinux.bin.gz uImage.img
mkimage -A nios2 -O linux -T filesystem -C gzip -a 0x00c00000 -e 0x00c00000 -n 'romfs EP1C6' -d romfs.bin.gz romfs.img
but previously ,when i have load onlt romfs.bin (uncompress)at that time ,i got perfect o/p,but now when i use gzip file then kernel is booting but it is not able to uncompress romfs.img
please help me
    You should not compress romfs.
    And romfs should be write to flash on the romfs partition in the mtd map.
    It would be easier if you use initramfs. no more romfs headache.
    --- Quote Start ---
    originally posted by hippo@Jun 30 2006, 06:38 AM
    you should not compress romfs.
    and romfs should be write to flash on the romfs partition in the mtd map.
    it would be easier if you use initramfs. no more romfs headache.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16543)
    --- quote end ---
    --- Quote End ---
    thanks hippo
    but
    can you tell me how to do initromfs? please
    Hi All,
    > mkimage -A nios2 -O linux -T filesystem -C gzip -a 0x00c00000 -e 0x00c00000 -n &#39;romfs EP1C6&#39; -d
    Just a note: passing a ramdisk image to the kernel as a parameter from a bootloader will not work.
    The default kernel image (for Nios II) does not recognize any parameters (e.g. command line,
    bd_t, ramdisk) passed to it from a boot loader. Hopefully, we will address this issue in the kernel
    soon -- then add support in u-boot.
    hippo, we should discuss this some time ... as it can affect the bzImage design.
    --Scott
