19 years agoUncompressing Linux...ERROR
Dear all, I meet a weird problem on building image. The source I use is uClinux-dist-20060803 with patch v18. There are also some custom applications added into the image. All co...
19 years agoyou are right, nacide.
although my problem happens with nios2-download program, it is also the byte alignment issue. after tracing the booting process, i found that if the size of generated vmlinux.bin.gz (in linux-2.6.x/arch/nios2nommu/boot/compressed/) is odd, i will get "length error" during uncompressing kernel. it is because that in function gunzip (linux-2.6.x/lib/inflate.c), it always gets wrong length value when size of vmlinux.bin.gz is odd. orig_crc[23:00] is correct, but orig_crc[31:24](the last byte we get) is wrong. the length value in zImage is correct, but it gets wrong value during uncompressing. what i did is trying to add some spaces at the end of .data section in linux-2.6.x/arch/nios2nommu/boot/compressed/vmlinux.scr in order to make sure that we can get correct orig_crc[31:24] byte without byte alignment issue.SECTIONS
.data : {
input_len = .;
LONG(input_data_end - input_data) input_data = .;
*(.data)
input_data_end = .;
LONG(0) /* for byte alignment issue */
} now i can always get the workable image after that patch. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif here are steps i do to generate image. 1. make clean vendor_hwselect SYSPTF=~/project/ptf/nios2.ptf 2. make romfs 3. make 4. make linux image
