20 years agoUnable to mount root fs on unknown-block
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Linux version 2.6.11-uc0 (new@MICROSOF-7693F8) (gcc version 3.4.1 (Altera Nios I I 5.1 b73))# 3 Mon Aug 21 10:49:42 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 003F0000 Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6340k/8192k RAM, 0k/0k ROM (1439k kernel code, 295k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80681158 (irq = 2) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize dmfe_probe:eth0, 50000 Khz Nios <DM9000> eth0 I/O: 80681000, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 50000 Khz Nios microtronix[mtd]: RAM probe address=0x200000 size=0x0 Creating 1 MTD partitions on "RAM": 0x00000000-0x00000000 : "ROMfs" mtd: partition "ROMfs" is out of reach -- disabled microtronix[mtd]: set ROMfs to be root filesystem NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) NET: Registered protocol family 1 NET: Registered protocol family 17 end_request: I/O error, dev mtdblock0, sector 2 EXT2-fs: unable to read superblock end_request: I/O error, dev mtdblock0, sector 0 FAT: unable to read boot sector VFS: Cannot open root device "mtdblock0" or unknown-block(31,0) Please append a correct "root=" boot option Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0) why?Can you help me ?No RepliesBe the first to reply
