20 years agounable to load cramfs
hello friends i am using cramfs .i have compressed kernel . i have stored u-boot at 0x0 ,cramfs at 0x00100000 and kernel image at 0x00020000. my flash is 2MB(0x00000000 to 0x00200000).and s...
20 years agohi scott
so much thanks.......infinite atleast ,now kernel is able to find which is fs is there. but still now i have problem now, i got massegs on terminal like uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 7040k/8192k RAM, 0k/0k ROM (800k kernel code, 235k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80221080 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize UP3 map: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available RedBoot partition parsing not available Using altera development partition definition Creating 2 MTD partitions on "altera map": 0x00100000-0x00200000 : "romfs" 0x00000000-0x00100000 : "loader/kernel" VFS: Mounted root (cramfs filesystem) readonly. Freeing unused kernel memory: 48k freed (0x8e4000 - 0x8ef000) Warning: unable to open an initial console. Kernel panic - not syncing: No init found. Try passing init= option to kernel. if i think init is not there ,then it should be not worked when same fs is used as romfs.bin because i got kernel o/p ,when i used same fs without compress as romfs. please help me.
