Unable to load Ashling Riscfree NiosV libraries
Whenever I start RiscFree, Eclipse loads but I see none of the actual plugins for NiosV.
Can you specify what observation that leads to your hypothesis that Nios V plugin is not integrated?
The Ashling RiscFree IDE is built-in with Nios V and HPS plugin once installed. You are not required to install custom extensions/plugins.
Thus, it is unusual that Nios V plugin is missing in your RiscFree IDE.
If I were to guess, I think:
You were referring to the doc version 25.3.1, but it is RiscFree IDE v23.1 that is installed.
As such, you are experiencing missing plugins like the "Import Nios V CMake Project" button.
In truth, the "Import Nios V CMake Project" button is yet to be introduced in RiscFree IDE v23.1, as documented in the doc version 23.1.
Liang Yu
Hello, so:
there is nothing in my entire ashling riscfree window that refers to NiosV, not in new project wizard, not in import wizard, nowhere else. I will anyway double check on my server if the description explained in the manual you have just linked is realistic for our usecase.
- LiangYuG_Altera8 months ago
Contributor
Hi Cloudscraper ,
I see, you are correct.
I reviewed the RiscFree IDE v23.1, and the following are my observations.not in new project wizard
Most Nios V projects are imported BSP & APP projects. Currently, there is no equivalent "File > New > Nios II Application and BSP from Template" in RiscFree IDE.
In RiscFree IDE v23.1, the import wizard is based on "File > New > Project > C/C++ > C++ Project". So, there is no "Nios V" text throughout the whole flow. But there will be a dedicated import feature called Import Nios V CMake Project starting from RiscFree IDE v24.1.
nowhere else
Debugging side of things --- Nios V is using the RISC-V Hardware Debugging run/debug configuration option. So, another no "Nios V" text workflow.
Thanks for your help. I hope that my hypothesis is valid, and you will be unblocked soon.
If possible, please share your expected first impression. We and our partner, Ashling are interested to hear more to make the tool more intuitive.
Liang Yu- Cloudscraper7 months ago
Hello and thank you again for your detailed answer,
I have now realized that Ashling 23.1 is a bit more rudimental than more recent versions, but thanks to your answer and some research among the documents, we were able to import our application and our BSP and reference them together, thus we were able to complete a project build inside the Ashling RiscFree v23.1 environment.
The standing issue now lies in the Debugging component of Ashling RiscFree.We have, in fact, tried two different approaches:
- using Ashling RiscFree IDE v23.1 as our debugging medium
we get the error "selected debug probe is not available for debug session"
- using the Ashling RiscFree extension for VS Code instead
Both approaches have been failing us, that's why I am attaching a couple screenshots above of error messages we have been receiving.
This is what the jtagconfig launched from our NiosV-Shell is reporting us:
I have started wondering about user access/ user permissions in regards to these new errors popping up: have there been any previous reports of access limitations caused by lackluster user privileges or user permissions?
- LiangYuG_Altera7 months ago
Contributor
May I kindly ask to reopen a new post for the new issue?
- selected debug probe is not available for debug session from Ashling RiscFree IDE v23.1 and Ashling RiscFree VSCode v24.1
This is a forum post, and it is more convenient for other forum members that every post is associated with a single question & solution.
Since the same error message from Ashling GDBServer is captured in IDE & VSCode, we can treated them as a single issue. Thus, a single new post will do.
Rest assure that once the post are up, I will immediately reply to the post and support you accordingly.
Subsequently, this post will be closed with the following solution.
Liang Yu
