Unable to fill up the SDRAM memory
Hi IOzan,
Thank you for joining this Intel Community.
May I know what is your SDRAM width?
Let's say if your SDRAM width is 8 bits, then your offset will be +4. If the width is equal to 16 bits, then the offset will be +2.
Also, to perform read/write to memory, using "IOWR/IORD" signal is the best way. I recommend you to use this way and change the offset.
If this doesn't help, please send us the design for debugging purpose
NAli1
- IOzan7 years ago
I'm sorry but after following the exact tutorial instructions as well as your suggestions (in the previous email), the SDRAM is still only partially working (works well up to first ~144 cycles).
My On my DE2-115 EVM I have two 64MB (128M (32x32)) SDRAMs from the model of IS42S16320B.
I don't really know how to move forward with this problem... L.
I'm attached the complete project for you to have a quick look of the configuration (If you can…).
Thank you very very much…
Idan
- NurAida_A_Intel7 years ago
Dear IOzan,
Just to let you know that we are still looking into your issue. I will keep you updated from time to time. Thank you very much for you patience.
NAli1
