12 years agoUnable to debug Nios Applications under Linux
Hello, I'm using Nios II EDS 14.0 under Linux (CentOS 6.5) and I actually can't debug any applications: they run fine (by clicking on "run as Nios II Hardware") but they won't debug. I get this mess...
11 years agoHi Gjoli,
tried export PYTHONPATH=/usr/ but doesn't do the trick.... I'm on Ubuntu 14.04 64bit with Quartus 14.0.2 installed. Are you sure that it worked for you with the same setup? Thanks!
