12 years agoUnable to debug Nios Applications under Linux
Hello, I'm using Nios II EDS 14.0 under Linux (CentOS 6.5) and I actually can't debug any applications: they run fine (by clicking on "run as Nios II Hardware") but they won't debug. I get this mess...
12 years ago --- Quote Start --- Hi, I'm having exactly the same issue running it on an Ubuntu 13.10 64bit. The seems to be, that it can't find the python libraries located in <installation dir>/quartus/common/python/lib/site.py . If I set PYTHONPATH to that directory before running eclipse, it says that there's an error in line 173 of site.py - so no real enhancement! I already launched a service request with the result, that Ubuntu is not a supported OS - just RedHat. Is there somebody that can confirm that NIOS is working under RedHat x64? Thanks! --- Quote End --- It seems that on Ubuntu 14.04, doing an export PYTHONPATH=/usr/ fixed the issue I am running on Ubuntu 12.04 and it doesn't work with this :( Anyone has a workaround for 12.04 other than migrating to 14.04 ?
