21 years agoUnable to connect to the Development Board
Hi I have a problem and I tried almost everything to fix it but nothing helped. Here it is: I have a Altera Cyclone Development Kit. When I try to connect the board to the PC, I always ...
21 years agoHi M!,
Only a few things come to mind: -Get the latest version of the Quartus programmer. -Make sure your MasterBlaster is actually the selected hardware. -Make sure you are connected to the JTAG, not the ASMI header. -Check the JTAG connector ... if it's backwards, it won't work ;-) > The COM port on the PC is set to the same boad rate as the port setting on > the Cyclone board (both at 9600). I'm not sure I understand this. Good Luck, --Scott
