12 years agoUnable to boot from on-chip RAM
Hi, I am using QuartusII version 11.1. I have designed a custom board with Cyclone IV E FPGA, EPCS16 configuration device, character LCD and some other ICs. I could successfully build a Qsys ...
12 years agoI would check that the elf file has everything in the expected places.
Run objdump -h foo.elf, objdump -P foo.elf and objdump -d foo.elf. -h list the elf sectoon headers. -P is the program headers (they are normally used by a program loader). -d is the disassembly. You should have a small piece of code at the reset vector that does little more than jump to (probably) alt_main.
