16 years agoUnable call alt_main() inside _start routine when using SSRAM as program memory
Hi, My Application is not able call alt_main() inside _start routine when using SSRAM as program memory. I read the PC register and found that it is stop at "call alt_main" in *.objdump file ...
16 years agoFor shahzad
You must select the project you want to run in the projects list before selecting "Run as". Moreover, the first time you run a project you shouldn't select "Run as" but "Run..." instead; select appropriate settings and then Run. Next times you can use "Run as"
