21 years agoUkit's problem on FTP
When I copy file to /home/ftp directory it show error message "read-only file system". Then I used chmod to change the access permissions of the directory it also give error message "read...
21 years agoYou can use a bigger ramdisk. Right now the /ramfs.img is very small, you can replace it with a bigger one. But this needs to re-generate the romfs image.
An another alternative is to use nfs, if you have a Linux desktop. Regards, wentao
