17 years agoUINT64 error when compile STLport on Uclinux
uclinux-dist-20070130
patch 20070130
I have already finished the default uclinux compilation.
when adding some drivers for PIO_SWITCHES,PIO_BUTTONS,PIO_LCD..
#make(when compile the STLport part)
the error information is:
> patch 20070130 This is much too old and not supported any more since long. You need to follow the instructions in the Wiki ( http://www.nioswiki.com/installnios2linux (http://www.nioswiki.com/installnios2linux) ) (including using git for upgrading) to get a current tool chain. -Michael - Altera_Forum
<div class='quotetop'>QUOTE (mschnell @ Jul 14 2009, 12:41 PM) <{post_snapback}> (index.php?act=findpost&pid=23112)</div>
--- Quote Start --- > uclinux-dist-20070130 > patch 20070130 This is much too old and not supported any more since long. You need to follow the instructions in the Wiki ( http://www.nioswiki.com/installnios2linux (http://www.nioswiki.com/installnios2linux) ) (including using git for upgrading) to get a current tool chain. -Michael[/b] --- Quote End --- I follow the steps of this pdf. http://www.hs-augsburg.de/~carcass/nios2-u...cumentation.pdf (http://www.hs-augsburg.de/~carcass/nios2-uclinux/uclinux_nios2_devicedrivers_and_testapplication_documentation.pdf) from page 20 on the 4 Additional/Projectrelated Changes part. I use the same package as the writer. - Altera_Forum
<div class='quotetop'>QUOTE (babysnow @ Jul 15 2009, 03:57 AM) <{post_snapback}> (index.php?act=findpost&pid=23125)</div>
--- Quote Start --- I follow the steps of this pdf. http://www.hs-augsburg.de/~carcass/nios2-u...cumentation.pdf (http://www.hs-augsburg.de/~carcass/nios2-uclinux/uclinux_nios2_devicedrivers_and_testapplication_documentation.pdf) from page 20 on the 4 Additional/Projectrelated Changes part.[/b] --- Quote End --- Of course you are free to do this, but you will be on your own doing so. You will not get many valuable answers here, if you don't use the distribution as described in the Wiki. -Michael
