16 years agoUDP Read and Writing in SDRAM
Dear Friend's i am sucessfully able to read data through UDP but when i simultenauselly trying to write this received data in SDRAM it generate a message during run time and held operation. a...
16 years agoUsually both code and data are stored in sdram, unless you map them in other places changing syslib properties or directly through linker options.
Sure, code and initialized data are stored in flash eprom but they are copied upon boot into sdram (or sram or internal memory, wherever you have mapped each section). As I already posted in another similar thread, a safe and much simpler way to use sdram is: define a sdram buffer as a variable array, i.e. char bigbuffer[BUFSIZE] and then write to bigbuffer[myaddr] instead of using direct iowr. The linker automatically takes care of avoiding sdram corruption (provided you check myaddr<BUFSIZE in your code...) Cris
