15 years agoudp format transfer image
hi,do you all have any reference for transfer image in udp packet?i have search at web but found that no what i want.Thank you.
If you want the format for an ethernet frame with IP + UDP look at wikipedea
hi,i had look through wikipedia and i started to understand it.By the way, do u have any sample code that can allow to load into the my NEEK development board?With the sample code, i can play around the code and have a deeper understanding about hoe to use udp to transfer image via ethernet.Thank you.
