15 years agoucos+Nichestack TCP/IP stack problem in DE2
I'm using Quartus II 8.0 with DE2 board NIOS IDE console displays: " InterNiche Portable TCP/IP, v3.1 Copyright 1996-2007 by InterNiche Technologies. All rights reserved. prepped 0 int...
15 years agoThe Vendor ID has not read successfully as it's supposed in the DM9000A data sheet which has indicated as below:
write 0x28 to the index port, then read from data port, we should have got 0x46 but I always get 0xC07 whether reading from the index port or data port after writting the value 0x28 to the index port. would it be the timing issue? I have added the dm9000 _INSTANCE and _INIT to the file "alt_sys_init.c" manually.
