21 years agoUCOSII without flash
Hello I am tryin to run the web server example, with UCOS II on a board without a flash chip (but with an EPCS). Can it be done ? When I try to configure the LWIP stack in the project library p...
21 years agoYour problem is that the web server example stores the MAC address (ethernet address) in flash, you will need to re-write the get_mac_addr function chapter 9 of the Nios II Sofwtare Developers Handbook shoudl help you out.
