21 years agoucosII and lwip
Hi,everyone. Who knows the limitations of NiosII evaluation ? When I build the software temple of simple Socket Sever in NiosII 1.1 evaluation,it appears this error: Error *** No rule to ...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Hi,everyone. Who knows the limitations of NiosII evaluation ? When I build the software temple of simple Socket Sever in NiosII 1.1 evaluation,it appears this error: Error *** No rule to make target `D:/altera/kits/nios2/components/micrium_uc_osii/build/app.mk'. Stop. Error D:/altera/kits/nios2/components/micrium_uc_osii/build/app.mk: No such file or directory makefile simple_socket_server/Debug line 63 And another problerm is : I use NiosII 1.0(not evaluation) to build Hello ucosII temple which carried by itself .It also has problem as: Error *** [ext_flash.flash] Error 5 hello_ucosii_0 elf2flash: Error generating Flash file, exiting[Jun 27, elf2flash: Error reading boot copier[Jun 27, 2005 2] Please give me some advice .Thank you!!!!!!!! My QQ:332418170[/b] --- Quote End --- It's quite simple the eval copy of Nios does not contain MicroC/OS-II, so you're not going to have any look getting the LWIP/MicroC/OS-II examples running
