21 years agouC/OS-II LWIP pbuf_free fail
Has any one seen an issue with the following error durring run time: Assertion "pbuf_free: p->ref > 0" failed at line 567 in /cygdrive/c/applications /altera/kits/nios2/components/altera_lwip...
20 years agoSure, you have to re-generate the FPGA image, because the problem is in the CPU, not in the compiler or libraries.
--- Quote Start --- originally posted by julveste@Mar 23 2006, 03:52 PM hi
thanks, had a hard time with this as well.
i still have the pbuf_ref problem after i installed the altera's patch. do i have to re-generate the image or is it just a compilation problem ?
the dummy read mentioned, exactly what shall i put where ?
best regards
jan ulvesten
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13722)
--- quote end ---
--- Quote End ---
