21 years agouC/OS-II LWIP pbuf_free fail
Has any one seen an issue with the following error durring run time: Assertion "pbuf_free: p->ref > 0" failed at line 567 in /cygdrive/c/applications /altera/kits/nios2/components/altera_lwip...
20 years ago --- Quote Start --- originally posted by vlorenzo@Jan 4 2006, 04:56 PM does anyone know if this bug is also present in nios-ii 1.1? --- Quote End --- No, I don't know. Sure it is present in NiosII 5.0 and 5.1. But we have a little piece of code that can verify the problem:
#include <stdio.h># include <string.h># include <sys/alt_irq.h>
# define PATTERN_VAL 0xAAAAAAAA# define START_FILL_ADDR 0x01040000# define END_FILL_ADDR 0x011FFFFF# define DWORD_ADDR_1 0x010F1AB8 // 0x01XXXAA0-0x01XXXAB8# define DWORD_ADDR_2 0x01100ABC // Last dword of a cache line
int main()
static unsigned long * pdw1=(unsigned long *) DWORD_ADDR_1;
static unsigned long * pdw2=(unsigned long *) DWORD_ADDR_2;
static unsigned long * pdwCur;
// Disable interrupts
alt_irq_disable_all();
// Fill memory with pattern
memset((void *) START_FILL_ADDR,PATTERN_VAL,END_FILL_ADDR-START_FILL_ADDR+1);
while(1)
asm volatile
"movi r2,0x5555;"
"ldw r3,(%);"
"stw zero,(%);"
"stw r2,(%);"
: "+r" (pdw1),
"+r" (pdw2)
: "r2","r3"
// Check memory
pdwCur=(unsigned long *) START_FILL_ADDR;
while(pdwCur < (unsigned long *)(END_FILL_ADDR+1))
if(*pdwCur!=PATTERN_VAL && pdwCur!=pdw1 && pdwCur!=pdw2)
while(1);
pdwCur++;
return 0;
} If you execute this code on NiosII 5.0 and 5.1 with data cache enabled, it blocks on the while(1) cycle because of memory corruption. If you execute this code on a core without data cache, all is ok. I don't know if this code can run also on NiosII 1.1 (I don't know that version of the CPU). <div class='quotetop'>QUOTE </div> --- Quote Start --- In the lwIP support forum several posts relating to some not yet solved pbuff issues can be read, including at least one that could produce a "pbuf_free: p->ref > 0" assertion. Working in an FTP client, based on lwIP + uC/OS-II, we found that several pbuff related issues could arise when deleting a connection while lwIP was still trying to send un-acked TCP packets. A network sniffer was a great help for detecting that this was the cause. Waiting for all the packets (in the connection) being send and acked (or timed-out) was the work-around. The connection object has two fields that are not NULL when packets are still pending (waiting to be sent or acked). <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11943) --- Quote End --- [/b] --- Quote End --- I agree with this patch. In fact we modified some time ago the function netconn_delete to wait for both conn->pcb.tcp->unsent and conn->pcb.tcp->unacked to be NULL before deleting the connection. We had a problem with a web server: sometimes not the whole queue was flushed and the html page was truncated. However the assertion was still present. Once modified the pbuf_header function in order to avoid the unlucky sequence of instruction that "fake" the cache controller (just add a dummy read operation before the return statement) we never got the error anymore.
