20 years agouClinux without Flash (again)
I decided to give uClinux a try on my custom board, but I only have an SD card slot, no CFI. When reading the install guide for uClinux, and when trying it, it won't let me build a kernel project...
20 years agohi,mountain8848
you build the kernel under windows or linux? --- Quote Start --- originally posted by mountain8848@Dec 12 2005, 11:05 PM thank jdhar[/b] and hippo so much, I worked out the right vmlinux, which can bootup with initramfs. --------------------------------------------------------------- I crated ROOTFS half-automatically & half-manually 1. zip win pc ROOTFS 2. copy to linux pc 3. unzip -a in order to dos2linux 4. modify them properly: such as symbolic link files (ln -fvs * *)and /dev (mknod) 5. ln -fvs ./busybox init --------------------------------------------------------------- I tested by : 1. ftp vmlinuc to win pc 2. nios2-download -g vmlinux 3. test telnet, ping .... ok --------------------------------------------------------------- other problems: 1. I just got vmlinux in <linux-2.6.x> directory. I'd like to build out vmlinux.bin in order to let u-boot to boot or flash-programmer. How to do it ? 2. Could you send me the webpages about nios2-linux toolchain in marc'shttp://scorpius.homelinux.org/~marc/nios2.html (http://scorpius.homelinux.org/~marc/nios2.html) to [email protected]? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11493) --- Quote End --- [/b] --- Quote End ---
