20 years agouClinux without Flash (again)
I decided to give uClinux a try on my custom board, but I only have an SD card slot, no CFI. When reading the install guide for uClinux, and when trying it, it won't let me build a kernel project...
20 years agoHere is the kernel config: .config
NOTE: only one red line is difference, cause it will cause error when it is "=y" # Automatically generated make config: don't edit# Linux kernel version: 2.6.11-uc0# Sun Dec 11 19:35:42 2005# # CONFIG_MMU is not set# CONFIG_FPU is not set CONFIG_UID16=y CONFIG_RWSEM_GENERIC_SPINLOCK=y# CONFIG_RWSEM_XCHGADD_ALGORITHM is not set CONFIG_GENERIC_CALIBRATE_DELAY=y # # Code maturity level options# CONFIG_EXPERIMENTAL=y CONFIG_CLEAN_COMPILE=y CONFIG_BROKEN_ON_SMP=y # # General setup# CONFIG_LOCALVERSION=""# CONFIG_BSD_PROCESS_ACCT is not set# CONFIG_SYSCTL is not set# CONFIG_AUDIT is not set CONFIG_LOG_BUF_SHIFT=14# CONFIG_HOTPLUG is not set# CONFIG_IKCONFIG is not set CONFIG_EMBEDDED=y #CONFIG_KALLSYMS is not set # original : CONFIG_KALLSYMS=y# CONFIG_KALLSYMS_EXTRA_PASS is not set CONFIG_FUTEX=y CONFIG_EPOLL=y# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_CC_ALIGN_FUNCTIONS=0 CONFIG_CC_ALIGN_LABELS=0 CONFIG_CC_ALIGN_LOOPS=0 CONFIG_CC_ALIGN_JUMPS=0 CONFIG_TINY_SHMEM=y # # Loadable module support# # CONFIG_MODULES is not set # # Processor type and features# # # Platform dependant setup# CONFIG_NIOS2=y# CONFIG_MICROTRONIX_UKIT is not set# CONFIG_MICROTRONIX_STRATIX is not set# CONFIG_MICROTRONIX_CYCLONE is not set# CONFIG_MICROTRONIX_PSK is not set CONFIG_ALTERA_STRATIX=y# CONFIG_ALTERA_STRATIX_PRO is not set# CONFIG_ALTERA_STRATIX_II is not set# CONFIG_ALTERA_CYCLONE is not set# CONFIG_ALTERA_CYCLONE_1C12_EVAL is not set# CONFIG_NIOS2_HW_MUL_OFF is not set CONFIG_NIOS2_HW_MUL=y# CONFIG_NIOS2_HW_MULX is not set # # Miscellaneous Options# # CONFIG_AVALON_DMA is not set# CONFIG_PIO_DEVICES is not set CONFIG_EXCALIBUR=y# CONFIG_BREAK_ON_START is not set# CONFIG_LARGE_ALLOCS is not set CONFIG_RAMKERNEL=y# CONFIG_PREEMPT is not set CONFIG_CMDLINE="" # # Bus options (PCI, PCMCIA, EISA, MCA, ISA)# # CONFIG_PCI is not set # # PCCARD (PCMCIA/CardBus) support# # CONFIG_PCCARD is not set # # PC-card bridges# # # PCI Hotplug Support# # # Executable file formats# CONFIG_KCORE_AOUT=y CONFIG_KCORE_ELF=y CONFIG_BINFMT_FLAT=y# CONFIG_BINFMT_ZFLAT is not set# CONFIG_BINFMT_SHARED_FLAT is not set# CONFIG_BINFMT_MISC is not set # # Power management options# # CONFIG_PM is not set # # Device Drivers# # # Generic Driver Options# CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y# CONFIG_FW_LOADER is not set # # Memory Technology Devices (MTD)# # CONFIG_MTD is not set # # Parallel port support# # CONFIG_PARPORT is not set # # Plug and Play support# # # Block devices# # CONFIG_BLK_DEV_FD is not set# CONFIG_BLK_DEV_COW_COMMON is not set# CONFIG_BLK_DEV_LOOP is not set# CONFIG_BLK_DEV_RAM is not set CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_INITRAMFS_SOURCE="/home/uc/root" CONFIG_INITRAMFS_ROOT_UID=500 CONFIG_INITRAMFS_ROOT_GID=500# CONFIG_CDROM_PKTCDVD is not set # # IO Schedulers# CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_AS=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y # # ATA/ATAPI/MFM/RLL support# # CONFIG_IDE is not set # # SCSI device support# # CONFIG_SCSI is not set # # Multi-device support (RAID and LVM)# # CONFIG_MD is not set # # Fusion MPT device support# # # IEEE 1394 (FireWire) support# # CONFIG_IEEE1394 is not set # # I2O device support# # # Networking support# # CONFIG_NET is not set# CONFIG_NETPOLL is not set# CONFIG_NET_POLL_CONTROLLER is not set # # ISDN subsystem# # # Telephony Support# # CONFIG_PHONE is not set # # Input device support# # CONFIG_INPUT is not set # # Userland interfaces# # # Input I/O drivers# # CONFIG_GAMEPORT is not set CONFIG_SOUND_GAMEPORT=y# CONFIG_SERIO is not set# CONFIG_SERIO_I8042 is not set # # Input Device Drivers# # # Character devices# # CONFIG_VT is not set# CONFIG_SERIAL_NONSTANDARD is not set# CONFIG_NIOS_SPI is not set# CONFIG_NIOS_BUTTON is not set # # Serial drivers# # CONFIG_SERIAL_8250 is not set # # Non-8250 serial port support# CONFIG_NIOS_SERIAL=y CONFIG_NIOS_SERIAL_CONSOLE=y# CONFIG_SERIAL_AJUART is not set# CONFIG_UNIX98_PTYS is not set# CONFIG_LEGACY_PTYS is not set # # IPMI# # CONFIG_IPMI_HANDLER is not set # # Watchdog Cards# # CONFIG_WATCHDOG is not set# CONFIG_RTC is not set# CONFIG_GEN_RTC is not set# CONFIG_DTLK is not set# CONFIG_R3964 is not set # # Ftape, the floppy tape device driver# # CONFIG_DRM is not set# CONFIG_RAW_DRIVER is not set # # I2C support# # CONFIG_I2C is not set # # Dallas's 1-wire bus# # CONFIG_W1 is not set # # Misc devices# # # Multimedia devices# # CONFIG_VIDEO_DEV is not set # # Digital Video Broadcasting Devices# # # Graphics support# # CONFIG_FB is not set # # Sound# # CONFIG_SOUND is not set # # USB support# # CONFIG_USB is not set CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB_ARCH_HAS_OHCI=y # # NOTE: USB_STORAGE enables SCSI, and 'SCSI disk support' may also be needed; see USB_STORAGE Help for more information# # # USB Gadget Support# # CONFIG_USB_GADGET is not set # # MMC/SD Card support# # CONFIG_MMC is not set # # InfiniBand support# # CONFIG_INFINIBAND is not set # # File systems# # CONFIG_EXT2_FS is not set# CONFIG_EXT3_FS is not set# CONFIG_JBD is not set# CONFIG_REISERFS_FS is not set# CONFIG_JFS_FS is not set # # XFS support# # CONFIG_XFS_FS is not set# CONFIG_MINIX_FS is not set# CONFIG_ROMFS_FS is not set# CONFIG_QUOTA is not set# CONFIG_DNOTIFY is not set# CONFIG_AUTOFS_FS is not set# CONFIG_AUTOFS4_FS is not set # # CD-ROM/DVD Filesystems# # CONFIG_ISO9660_FS is not set# CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems# # CONFIG_MSDOS_FS is not set# CONFIG_VFAT_FS is not set# CONFIG_NTFS_FS is not set # # Pseudo filesystems# CONFIG_PROC_FS=y CONFIG_SYSFS=y# CONFIG_DEVFS_FS is not set# CONFIG_TMPFS is not set# CONFIG_HUGETLB_PAGE is not set CONFIG_RAMFS=y # # Miscellaneous filesystems# # CONFIG_ADFS_FS is not set# CONFIG_AFFS_FS is not set# CONFIG_HFS_FS is not set# CONFIG_HFSPLUS_FS is not set# CONFIG_BEFS_FS is not set# CONFIG_BFS_FS is not set# CONFIG_EFS_FS is not set# CONFIG_CRAMFS is not set# CONFIG_VXFS_FS is not set# CONFIG_HPFS_FS is not set# CONFIG_QNX4FS_FS is not set# CONFIG_SYSV_FS is not set# CONFIG_UFS_FS is not set # # Partition Types# # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y # # Native Language Support# # CONFIG_NLS is not set # # Kernel hacking# # CONFIG_FULLDEBUG is not set# CONFIG_FRAME_POINTER is not set# CONFIG_MAGIC_SYSRQ is not set# CONFIG_NO_KERNEL_MSG is not set # # Security options# # CONFIG_KEYS is not set# CONFIG_SECURITY is not set # # Cryptographic options# # CONFIG_CRYPTO is not set # # Hardware crypto devices# # # Library routines# # CONFIG_CRC_CCITT is not set# CONFIG_CRC32 is not set# CONFIG_LIBCRC32C is not set
