20 years agouClinux without Flash (again)
I decided to give uClinux a try on my custom board, but I only have an SD card slot, no CFI. When reading the install guide for uClinux, and when trying it, it won't let me build a kernel project...
20 years agonow I develop linux kernel in linux(redhat 9.0)
1. copy /bin/nios2-elf-.... to pc from CD of nios2linux 2. set PATH 3. make hwselect ; make menuconfig ; make (like you stated out) the .config is much like you post in this thread. here is linux logversion 3.4.1 (Altera Nios II 5.0 b73b))# 4 Sun Dec 11 19:38:18 CST 2005
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 15232k/16384k RAM, 0k/0k ROM (633k kernel code, 330k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Linux NoNET1.0 for Linux 2.6
NIOS serial driver version 0.0
ttyS0 (irq = 3) is a builtin NIOS UART
ttyS1 (irq = 7) is a builtin NIOS UART
ttyS2 (irq = 8) is a builtin NIOS UART
ttyS3 (irq = 9) is a builtin NIOS UART
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
