20 years agouClinux without Flash (again)
I decided to give uClinux a try on my custom board, but I only have an SD card slot, no CFI. When reading the install guide for uClinux, and when trying it, it won't let me build a kernel project...
20 years ago --- Quote Start --- originally posted by hippo@Nov 30 2005, 01:24 AM great!! http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/laugh.gif
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
i haven't modified inittab at all since buildroot created this <--- should i do this??? --- Quote End --- You can use this, and add the line of /bin/sh as you already did it. I would like to invite you to post this as a project on the forum. This would be very helpful to those who develope custom boards. I am working on a PIO based MMC/SD card driver, with my spare time. I shall post it as another project when ready. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=11258)</div> [/b] --- Quote End --- I take it you are using true MMC mode instead of SPI, which is why you are using PIO? That should be really cool once it is done; I am actually moving away from MMC/SD now to CF just because of lack of driver support http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Is the driver included in the kernel any good, or does that not even work? When I'm more comfortable with playing around with the boot process of linux (I have already learnt so much!), I will definitely either post a project or make a sort of extension to Marcs instructions - anyone reading this thread should get all the information they need as I knew nothing when I started, but it would be nice to have it one place!
