20 years agouClinux without Flash (again)
I decided to give uClinux a try on my custom board, but I only have an SD card slot, no CFI. When reading the install guide for uClinux, and when trying it, it won't let me build a kernel project...
20 years agoYa, I do'nt think it's possible in windows - I just trashed the whole microtronix tree, grabbed the source from the install file, converted it using zip/unzip and installed the converted version, made a new kernel project in the IDE, and tried to compile with no options, and it still gave me the same error...
Since you said the NIOS 2 Linux bins work fine, I won't try using the buildroot method - and I agree that linux should be faster more efficient, it's just all this pain in setting it up. I will try the binaries when I'm at my linux computer, and let you know... Thanks so much!
