20 years agouClinux without Flash (again)
I decided to give uClinux a try on my custom board, but I only have an SD card slot, no CFI. When reading the install guide for uClinux, and when trying it, it won't let me build a kernel project...
20 years agoI have MMC/SD sockets on some of my boards.
And I am going to try out. The NIOS SPI is not good for MMC/SD. I am using PIO ports instead. I think using "root=/dev/mmc" is not a good idea. After the system boot, the mmc/sd card may be unplug, and another be plug in later. So I am going to keep Initramfs as root fs. The devfs was obsolete, and will be replaced by udev. I am going to mknod mmc with fixed device number. I will also check mmc driver from newer kernel.
