20 years agouClinux without Flash (again)
I decided to give uClinux a try on my custom board, but I only have an SD card slot, no CFI. When reading the install guide for uClinux, and when trying it, it won't let me build a kernel project...
20 years agoSorry, the sym link should be, ln -s /sbin/init /usr/src/uclinux_fs/init
The /sbin/init program, linked to busybox, will read /etc/inittab, which is ,eg # Startup the system null::sysinit:/bin/mount -t proc proc /proc null::sysinit:/bin/mount -t sysfs sysfs /sys null::sysinit:/bin/mount -t usbfs none /proc/bus/usb # Set up a couple of getty's ::askfirst:/bin/sh You can remove files in /usr/include and /usr/lib to save space. When we design custom board, most drivers are under construction. The Initramfs need only ram, and a serial/jtag console driver is all that needed to start. When you have tested your custom mmc driver, you may disable Initramfs, and use the MMC/SD as root device, with the kernel command line "root=/dev/mmc0". You will need devfs to use mmc block device.
