21 years agouClinux without CFI compliant flash or EPCS
Hi, I am trying to setup uClinux on a custom board without CFI compliant flash. When I start a new kernel project from the Nios2 IDE, it fails beacause it doesn't find any CFI device. ...
21 years agoNo, when developing the plugins for the Nios II Linux Distribution, I found C symbols referencing the flash device that stores the kernel. So, I made it a requirement to specify a CFI compliant flash that would allow me to properly define the C symbols that the kernel required.
At this point, it is not possible to build the kernel without a CFI device in your system.... sorry about that. After examination of the code, it should be possible to do it but we need to perform some more testing first. I'll see if I can get some info for you on how to make the mod's and to build the kernel.
