21 years agouClinux without CFI compliant flash or EPCS
Hi, I am trying to setup uClinux on a custom board without CFI compliant flash. When I start a new kernel project from the Nios2 IDE, it fails beacause it doesn't find any CFI device. ...
21 years agoHi cetic,
Did you disable CFI in the MTD config for your kernel? Or were you unable to get that far? > Something else : I plan to use my AMD flash to boot the system, and my > NAND flash as a filesystem. > Is this possible ? Is there any restriction ? Several AMD parts are supported by the jedec chip driver ... but this may not matter if you're not using it for a filesystem. I don't believe there is a NAND chip driver in the 2.6 kernel ... so you'll probably need to code one up for a read/write filesystem. If you're planning on a read-only filesystem on the NAND, you can just use a generic rom driver. Regards, --Scott
