13 years agouClinux version 3.7 boot problem related to: mm bootmem.c:352 mark_bootmem()
Hi, I hope all is well and i thank you in advance for your time. In bold you find the relevant information to try and save you time reading this thread (i hope you don't find the bold lettering to be...
13 years agoThank you very much for your respond. I did manage to bypass my last problem by going into Advance Setup-> and change the "Set custom kernel MMU region base address", and the "Set custom kernel region base address", since my MMU base address is "0x000" and DDR2 RAM base address is "0x06000000" (with virtual memory, this base address is 0xC6000000).
It started to move along until I get this bug/failure message: Unhandled exception# 12 in kernel mode r1: c6000cc0 r2:00000000 r3: 00000b1c r4: 80000000 r5: 2aac70c0 r6: 00000f40 r7: ffffe0000 r8: c7049c88 r13: c704ede0 r14: c655cbb4 r15: 00000001 ra: c60b553c fp: c7c06ad4 sp: c7c17d5c gp: 00000000 ea: c60b512c estatus: 00000001 BUG: failure at /root/Desktop/nios2-linux/linux-2.6/mm/slab.c:501/page_get_cashe()! Kernel panic - not syncing: BUG! Have you seem this before? Any help is greatly appreciated.
