11 years agouClinux using Nios II e-core
Hello Everyone, I wanted to see if anyone has tried uClinux on Nios II e-core.? I'm trying to run uClinux 2.6.30 on Nios II e-core. In the make menuconfig, I have turned off Hardware Mult...
11 years agohello ,i am trying to transplant the uclinux to my cyclone IV , i found a detail description about uClinux on Altera Wiki page, but i encountered several problems as follows:
1>my environment is ubuntu 12.04 - 64bit ,i cannot success to configure my toolchain (prebuild toolchain nios2gcc-20080203.tar.bz2 )PATH right:i add this line in ~/.profile:PATH=/opt/nios2/bin:$PATH;export . but nios2-linux-uclibc-gcc -v failed; then i chose to use ubuntu 11.04 32-bit ,it works; so, what is your linux version ? 2>I cannot download http://sopc.et.ntust.edu.tw/pub/linux/nios2-linux-20100621.tar ,it seems the link is out of work; so i use ftp://ftp.altera.com/outgoing/nios2-linux/20120802/ instead ; but when i come into uclinux-dist:# make menuconfig ,it failed;said that : Are you do your job as the same as Wiki page do ?? now ,i cannot make any progress ,
