17 years agouClinux: Use the alternative touch screen driver
Hi, I tried to use an "elo serial touch" driver (enabled in the uClinux kernel config) for an external display, connected to my Nios II Embedded Evaluation Kit. Unfortunately I'm new to the w...
16 years agoHi,
I'm having a hard time to communicate with the external touch controller. I specified the app "inputattach" with proper parameters. Driver for the touch controller (Elo) was recognized (Inputattach running in background). But testing event0 (assigned to "elo touch" driver) has no result. I also tried the console device via serial port (Terminal emulator: HyperTerminal) which worked out fine. As earlier mentioned "setserial" brings still the following report: /> setserial -a /dev/ttyS0 /dev/ttyS0, Line 0, UART: undefined, Port: 0x0000, IRQ: 6 Baud_base: 3125000, close_delay: 50, divisor: 0 closing_wait: 3000 Flags: spd_normal Main Configuration of the kernel: + Device Driver -> Char. devices -> Virtual terminal + Device Driver -> Input device supp. -> Event interface + Device Driver -> Input device supp. -> Event debugging + Device Driver -> Input device supp. -> Touchscreens -> Elo serial touch + Device Driver -> Input device supp. -> Hardware I/O ports Serial port line discipline enabled + Device Driver -> Char. devices -> Serial drivers -> Altera UART support enabled (default baudrate 9600), Altera JTAG UART support (+ console support)) (mouse and keyboard not included yet) Am I missing some options? PS: I also tried to activate the serial drivers "8250/16550 and compatible serial support" (Device drivers -> Char. devices -> serial drivers) but an error appears during compilation stating: ../nios2-linux/linux-2.6/drivers/serial/8250c:104:24: asm/serial.h: no such file or directory..(compilation aborted) I would appreciate if someone could help me on that problem. Thank you in advance! D.
