17 years agouClinux: Use the alternative touch screen driver
Hi, I tried to use an "elo serial touch" driver (enabled in the uClinux kernel config) for an external display, connected to my Nios II Embedded Evaluation Kit. Unfortunately I'm new to the w...
17 years agoPlease check wiki at,
http://wiki.archlinux.org/index.php/attaching_serial_input_devices_to_the_kernel_input_system event test is used to test /dev/input/event0...etc, but not /dev/ttyS0. Did you config "Serial port line discipline"? Did you check if the uart can talk with the serial touch screen? Did you config "event interface"? Did you try "event-debug"? - Hippo
