11 years agoUclinux-unrecognized instruction initda
Hi everyone, I'm trying to build Uclinux on kit Cylone II DE II. I followed the instructions from this http://www.alterawiki.com/wiki/installnios2linux I almost finish this; however, when I e...
11 years agoHi,
--- Quote Start --- {standard input}: Assembler messages: {standard input}:365: Error: unrecognised instruction initda make[3]: *** [arch/nios2/mm/memory.o] Error 1 make[2]: *** [arch/nios2/mm] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/root/nios2-linux/linux-2.6' make: *** [linux] Error 1 --- Quote End --- Maybe, your compiler does not support the instruction 'initda'. Can you rewrite it by 'initd' ? Kazu
