11 years agouClinux TSE not working
Hello, i have a problem with my Ethernet on the DE2-115 Board using uClinux. When i set up "eth0":
root:/> ifconfig eth0 192.168.14.92 up
eth0 Link encap:Ether...
11 years agoHi,
To Mr. RoyalOpino --- Quote Start --- The problem, why my TSE was not working, relays to wrong constrains. My design now is as followed: --- Quote End --- May I interpret that you succeeded using your TSE ? To Mr. fdsa --- Quote Start --- core dumped... with the same result 2: Code: r1: c026ec90 r2: c0354000 r3: c0354000 r4: c0354000 r5: 00000001 r6: 00000000 r7: 00000000 r8: 00000000 r9: 00000008 r10: 00000171 r11: c035aacc r12: c0356a3c r13: c0356a40 r14: ffffffe4 r15: c020d81c ra: c026f520 fp: deadbeef sp: c025ef9c gp: deadbeef ea: c026f614 estatus: 00000000 Unaligned access from kernel mode, this might be a hardware problem, dump registers and restart the instruction BADADDR 0xdeadbf0f cause 7 op-code 0xb800283a --- Quote End --- The core dumped contents are same for both 'nios2-terminal < linux.initramfs.srec' and 'nios2-download -g zImage' ? In my circumstances, 'nios2-download' which is using 'JTAG Debugger' will not work well. And it's better for us to make a new thread and discuss these things. Kazu
