11 years agouClinux TSE not working
Hello, i have a problem with my Ethernet on the DE2-115 Board using uClinux. When i set up "eth0":
root:/> ifconfig eth0 192.168.14.92 up
eth0 Link encap:Ether...
11 years agoHi,
--- Quote Start --- i have a problem with my Ethernet on the DE2-115 Board using uClinux. When i set up "eth0":
eth0 Link encap:Ethernet HWaddr 00:11:22:33:44:55
inet addr:192.168.14.92 Bcast:192.168.14.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:7 errors:7 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
Base address:0x2400
There are 7 errors on RX-Line. When i do "ping":
root:/> ping 192.168.14.14
PING 192.168.14.14 (192.168.14.14): 56 data bytes
^C
--- 192.168.14.14 ping statistics ---
3 packets transmitted, 0 packets received, 100% packet loss
RX packets:43 errors:43 dropped:0 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
Base address:0x2400
the Errors increase. Output of ethtool:
root:/> ethtool eth0
Settings for eth0:
Supported ports:
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 17
Transceiver: external
Auto-negotiation: on
Current message level: 0x00000000 (0)
Link detected: yes
root:/> ethtool -S eth0
NIC statistics:
aFramesTransmittedOK: 3
aFramesReceivedOK: 0
aFramesCheckSequenceErrors: 3
aAlignmentErrors: 1
aOctetsTransmittedOK: 138
aOctetsReceivedOK: 0
aTxPAUSEMACCtrlFrames: 0
aRxPAUSEMACCtrlFrames: 0
ifInErrors: 47
ifOutErrors: 0
ifInUcastPkts: 0
ifInMulticastPkts: 0
ifInBroadcastPkts: 0
ifOutDiscards: 0
ifOutUcastPkts: 0
ifOutMulticastPkts: 0
ifOutBroadcastPkts: 3
etherStatsDropEvent: 0
etherStatsOctets: 120993
etherStatsPkts: 47
etherStatsUndersizePkts: 0
etherStatsOversizePkts: 0
etherStatsPkts64Octets: 0
etherStatsPkts65to127Octets: 40
etherStatsPkts128to255Octets: 3
etherStatsPkts256to511Octets: 0
etherStatsPkts512to1023Octets: 0
etherStatsPkts1024to1518Octets: 1
etherStatsPkts1519toXOctets: 0
etherStatsJabbers: 0
etherStatsFragments: 3
ipaccTxConf: 0
ipaccRxConf: 0
ipaccRxStat: 0
ipaccRxStatSum: 0
What could be the Problem? --- Quote End --- Did you use a PLL to adjust the phase of Rx clock? Kazu
