16 years agouClinux trouble with making kernel
I've tried to follow the five steps at nioswiki but get some errors when i'm trying to make my own uClinux kernel. I created a new sopc-builder file and copied it to the kernel directory the followin...
16 years agoactris:
when i try the vendor_hwselect command i just get the following error: make[3]: *** No rule to make target `select'. Stop. But i think i saw somewhere that i, in the last version of the toolchain, don't have to use that command. I also couldn't see anything about it in the 5 steps on nioswiki. Is this correct? slacker: I have tried both with and without a MMU. The problem is that i'm unsure of what to choose after i have choosen nios2 or nios2nommu in menuconfig(and i have also used different sopc-files of course). I just used Enter for all the chioses( default i guess?...) and when i tried to customize the kernel myself i just changed to custom_fpga. Is there anyone that can provide me with the .sopc-files for Quartus/SOPC-builder v9.0 that you are sure working? An exact description of what to choose in menuconfig would also be appriciated. Thanks a lot!
