16 years agouClinux trouble with making kernel
I've tried to follow the five steps at nioswiki but get some errors when i'm trying to make my own uClinux kernel. I created a new sopc-builder file and copied it to the kernel directory the followin...
16 years agoYou don't have to do your first thing. Follow this :
In SOPC Builder do "Generate" Then copy you find your ".ptf" file (it's in you project directory). in you "nios2-linux/uClinux-dist/" directory do the following : make vendor_hwselect SYSPTF="XXXXXXXXX" replace the XXXX with your path to your ptf. Example : make vendor_hwselect SYSPTF="/opt/altera/project/myproject.ptf" Answer the question. In the same directory make menuconfig select Kernel/Libray/Default Selection/ Select Default all setting (lose changes) Exit -> Exit -> Save make That's all !
