16 years agouclinux toolchain installation ( cross compiler setting error)
Hi, I have just installed altera 9.1sp2 quartusII,nios2eds, nios2-linux-20090929.tar on centOS_5 from InstallNios2Linux tutorial. 1-hen i try to build the binary toolchain (the laptop is ...
14 years agoHi,
Iam trying to run uclinux on DE0-Nano board, iam using ubuntu12.04.And iam using nios2-linux-20090929. What i did cd nios2-linux git checkout test-nios2 cd uclinux-dist git checkout test-nios2. In thsese two cases i got "switched to branch test-nios2" and i set PATH variable also.And specified hardware architecture make vendor_hwselect sysptf=~/uclinux/hardware/de0-nano/simple/de0_nano_sopc.ptf ok only, but when i execute the make command in terminal the error showing as mentioned belowerrorr------------------------------------->>>>>>>>>>>>>>>>>> alex@alex:~/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist$ make ln -sf staging-pkg-config tools/nios2-linux-uclibc-pkg-config rm -f /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/../linux-2.6 O=/home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x -j4 zImage || exit 1 make[1]: Entering directory `/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6' /bin/sh: 1: nios2-linux-uclibc-gcc: not found make[2]: nios2-linux-uclibc-gcc: command not found
make[2]: nios2-linux-uclibc-gcc: command not found CHK include/asm-nios2/nios2.h perl -I/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6/arch/nios2/scripts /home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6/arch/nios2/scripts/gen_nios2.h.pl cpu sdram < /home/alex/uClinux/hardware/DE0-Nano/simple/DE0_Nano_SOPC.ptf > include/asm-nios2/nios2.h.tmp; if [ -r include/asm-nios2/nios2.h ] && cmp -s include/asm-nios2/nios2.h include/asm-nios2/nios2.h.tmp; then rm -f include/asm-nios2/nios2.h.tmp; else echo ' UPD include/asm-nios2/nios2.h'; mv -f include/asm-nios2/nios2.h.tmp include/asm-nios2/nios2.h; fi GEN /home/alex/Desktop/abc/uClinux/distro/nios2-linux/uClinux-dist/linux-2.6.x/Makefile CHK include/linux/version.h CHK include/linux/utsrelease.h SYMLINK include/asm -> include/asm-nios2 Using /home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6 as source for kernel CC scripts/mod/empty.o /bin/sh: 1: nios2-linux-uclibc-gcc: not found make[4]: *** [scripts/mod/empty.o] Error 127 make[3]: *** [scripts/mod] Error 2 make[2]: *** [scripts] Error 2 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/home/alex/Desktop/abc/uClinux/distro/nios2-linux/linux-2.6' make: *** [linux] error 1 Kindly Any help?
