16 years agouclinux toolchain installation ( cross compiler setting error)
Hi, I have just installed altera 9.1sp2 quartusII,nios2eds, nios2-linux-20090929.tar on centOS_5 from InstallNios2Linux tutorial. 1-hen i try to build the binary toolchain (the laptop is ...
16 years agoHello,Candido.I do what you told,but I also got a error.I changed the branch,when I make the image,there is a error:
{standard input}: Assembler messages: {standard input}:96: Error: unrecognised instruction flushda {standard input}:232: Error: unrecognised instruction flushda {standard input}:365: Error: unrecognised instruction flushda {standard input}:428: Error: unrecognised instruction flushda make[3]: *** [arch/nios2/mm/memory.o] 错误 1 LD arch/nios2/drivers/built-in.o make[2]: *** [arch/nios2/mm] 错误 2 make[2]: *** 正在等待未完成的任务.... make[2]: *** wait: 没有子进程。 停止。 make[1]: *** [sub-make] 错误 2 make[1]:正在离开目录 `/usr/local/src/nios2-linux/linux-2.6' make: *** [linux] 错误 1 root@lc-desktop:/usr/local/src/nios2-linux/uClinux-dist# why?Can you help me ?
