16 years agouclinux toolchain installation ( cross compiler setting error)
Hi, I have just installed altera 9.1sp2 quartusII,nios2eds, nios2-linux-20090929.tar on centOS_5 from InstallNios2Linux tutorial. 1-hen i try to build the binary toolchain (the laptop is ...
16 years agoHi Nguyen Tien,
In reply# 2 you must select test-nios2 branch with the command: $git checkout test-nios2 after, you can test your branch -> $ git -l branch bye
