16 years agouclinux toolchain installation ( cross compiler setting error)
Hi, I have just installed altera 9.1sp2 quartusII,nios2eds, nios2-linux-20090929.tar on centOS_5 from InstallNios2Linux tutorial. 1-hen i try to build the binary toolchain (the laptop is ...
16 years agoHi,
I was working with trunk branch and the nios2install is for test-nios2 branch, so i have read something about git tool 0: internet connected 1: switch to nios2-test at git repo ../uClinux-dist/ $git branch -l test-nios2 * trunk $git checkout test-nios2 $git branch -l * test-nios2 trunk 2 : update run ../nios2-linux/update 3: uClinux-dist/make menuconfig ERROR: there is not any rule for target config.arch building and i can see tha there is a link file named config.arch linked to vendors/Altera/nios2nommu/config.arch ¿? THANKS IN ADVANCE
